Re: F100 water pump housing melted
This thread is pretty old but it might help others, I ran into the same issue as you with my 1990 225 HP Yamaha. It has a 25" shaft and that bushing had apparently gotten hot. I purchased the 1980 22' Whaler Revenge, engine and trailer last spring so I'm not sure what happened but assume it was probably run on a hose for an extended time or simply wore out. A fully charged battery would make the engine turn but just barely, not even close to starting RPMs. I was concerned that it was an internal engine problem but I bought the whole rig with the idea of installing a new engine but thought I'd give rebuilding the old engine a go.
I couldn't get the lower unit to drop out so I thought the driveshaft was bound up within the engine coupler. I kept beating, prying, wedging and cussing the engine until I was finally able to get the lower unit free from its shackles. Afterwards the engine turned over without problem and the drive shaft turned fine on the bench. (WTH) I looked up in the midsection and was able to see that the culpret was the midsection bushing. I was able to get the snap ring out no problem with a pair of snap ring pliers. Getting the bulging bushing out was another story. Long story short, I basically and very carefully chiseled it out. The bronze housing started to crumble away in pieces after I was able to get a couple good precision hits on it.
I won't be able to run the engine on anything but a hose for a few more months so I just reinstalled the lower unit without it. I purchased a replacement and will be installing it before I do my shakedown cruises on the lake. After that experience, maybe it was just old age which led to its condition but I'd have major concerns running the engine for an extended period of time on the hose with the bushing installed, I'd have to assume that the seawater lubricates and keeps it cool during operations.
Good luck
