the tell tale temperature has been extremely hot. there have been no alarms from the two thermostats. after a long day fishing and running hard the trottle cut out like i pulled the trottle down to neutral and i didn't. it only happened at full speed. after replacing the water pump/impeller the water still spit out really hot even though it took a little longer to get hot.
how do i check if the thermostats are good?
any other ideas. water pressure gage...?
