Exterior cleaner/detergent that won't remove wax?
airdvr1227
Last Fall I picked up a pressure washer in an attempt to keep the boat looking nice while in it's slip. This Spring I spent hours cleaning, buffing, and waxing . I want to use a liquid with the pressure washer that won't remove the wax I spent so much time applying. Ideas?
rallyart
A biodegradable soap. No detergent, they specifically target oils which means they get wax.
Or, just water.. Most things you add are going to be bad for the water that you got your boat to enjoy.
If it's water spots you can use a mild vinegar solution rubbed on the spots.
dingbat
Two coats of quality wax and liberal use of a wash down hose and deck brush immediately upon returning to the dock negates the need to use anything harsh. We use a biodegradable boat soap when needed
airdvr1227
Thanks. The order of cleaning is pretty much the reverse. There are times when it's 2 weekends in between stays and she's docked 2 hours away. Most times we arrive to find her dirty and full of bird droppings etc. And, because we are at a stationary dock it's difficult to clean the side that is away from the dock and virtually impossible to clean below the rub rail on either side.
The plan would be to soak her down with a bio degradable cleaner (so far StarBrite deck cleaner looks about right) and rinse with the pressure washer.
