Exhaust Shutters?
Reming870
Before I pulled the OD I had two stainless plates in the bellows. Then upon disconnecting the motor to replace the transom I noticed this in the picture. Is this where the exhaust shutters are? Are the two small stainless plates I removed the shutters? They had holes drilled in them.
Starcraft Islander, 1984, 3.0L Merc, Alpha One OD
Re: Exhaust Shutters?
Ayuh,... They Used to be mounted to that pin...
You need New 1s...
