Exhaust oil dripping from lower unit housing
Berni Rubr
Hello all, after waking up my 2001 Johnson 90 2stroke and running it for a while in the driveway ( ran great ,started right up,idled good ,was winterized with stabil) I noticed after tilting the motor up for transport a small amount of exhaust oil running out of the lower unit seam and collecting at the speedo tube fitting. Just wondering is this normal after fogging,winterizing ect. Or is there a exhaust gasket bad? Was going to run the motor this week end and acing trains motion lampJohnson spray can on the Schrader valve but wanted to address this issue prior to using it and avoid possible damage. Thanks in advance Berni
Berni Rubr
Thanks! is there a exhaust chamber gasket I should inspect? After closer inspection I found that the Schrader has been slightly turned from possibly removing the air box. , maybe this caused an excessive rich condition for a short time. I closed the valve and the sounds like it is running fine. Thanks again Berni
F_R
Honorary Supreme Mariner
Take it and go boating. The oil coming out the exhaust is the fogging oil you put in it. It goes through the engine and out the exhaust. When it is all blown out, it will quit leaking out. That's just the way life is.
