I have a 1959 35hp evinrude with a bad exhaust housing seal and I haven't been able to find one.I wonder if someone has some info on where to get one or is it possible to make one. can't go fishing without it.all help will be appreciated
Get them as part of a gasket set, or save the old ones and make them yourself out of some cork gasket material from an auto parts store (need two. Check a parts blow up.)
I think you are speaking of the fat rubber seal that goes around it about half way down. Are you sure you need it? There are hundreds of motors running around with that seal in crappy condition. If you are getting smoke in the cowl, the main culprit is the o-ring (31) on top of the water pump housing. If it is a long shaft, there are two more o-rings on the extension tube (and the extension tube itself #72 ).
F-R that is the seal i was talking about. Didn't know i could run without it.Thanks,what is the purpose of that seal? I pulled the lower unit because water was getting into it. I placed an order with iboat for 4 items, it came today ,but they didn't send the L/U repair kit ,should to be here tomorrow,thanks for the diagram and info on the o-rings.
Well, it is not accurate to say that the seal is not important. It does stop smoke from going up through there, especially when idling at dockside and smoke is bubbling up around it. However, in gear and at any significant speed the underwater exhaust is buried in the wake behind the boat.
BTW, by any chance are you running it in a barrel? That will smoke it out big time.
