exhaust extension
sloopy
Re: exhaust extension
nope*<br /><br />*read some post on that subject
Bob_VT
Are you referring to modifying the exhaust ports? Yes in some cases having the ports reworked by a skilled mechanic and machine shop will allow more rpms. <br /><br />Additional modifications such as milling the heads for more compression, larger carbs, new reed valves are also part of a sincerely exspensive formula.<br /><br />You can post the question on http://forums.screamandfly.com/ and get some sound advice.<br /><br />An additional modification is use of a setback plate (jack plate with setback) can also increase speed.<br /><br />The best advice is instead of spending big $$$$ on an engine that is 27 years old I would consider re-powering. In the long run it will be cheaper.<br /><br />Bob :cool:
