The exhaust bellows down under the U-joint bellows?Hi, I replaced the bellows on my alphaone gen2 drive, when I tested the boat in the sea it sounds like the Exhaust bellow has slipped off, more engine noise then before, is there any problem using the boat this way?
Hopefully without too much of a thread highjack scenario here, by chance Muc, Jmunk and any others, do you all know of any floating rumors out there of the quicksilver bellows adhesive not holding up (or should I say on) like years past?MerCruiser tech support has been recommending super glue for exhaust bellows that slip off. Works for me, I use the gel version.
I had the oem clamp walking off the exhaust bellows on the bellhousing side of my gen 2 when I did it a couple years back. I think the transom end I put on with adhesive, bellhousing end popped off when I tightened the clamp. So b6 the time I got it to stay there was not much adhesive left, just snugged the clamp and left it , that was 3-4 years ago,Hopefully without too much of a thread highjack scenario here, by chance Muc, Jmunk and any others, do you all know of any floating rumors out there of the quicksilver bellows adhesive not holding up (or should I on) like years past?
I have been seeing on different, active MerCruiser talking websites like Facebook, where a number of active service technicians are starting to put on the U-joint and shift cable bellows on dry with said good results as some have experienced slipping off with adhesive used... The reason I ask is I myself had a new OEM bravo shift cable bellows with new OEM clamp slip off about 2 weeks ago with bellows adhesive used.
OEM clamp is being mentioned because recently a friend I was helping bought an aftermarket shift bellows and the clamp that came with it walked off as I was just tightening the clamp down not even to specification yet...Put the old OEM clamp on and worked out good thereafter.
Thanks...
Dad never used bellows adhesive on his personal boats with no ill effects. He always used it on customers boats for the sake of law suits... I've never owned a gen II or bravo but on my alpha I've done it both ways... I also only use the exhaust tube. No reason to **** around with bellows there IMO.Hopefully without too much of a thread highjack scenario here, by chance Muc, Jmunk and any others, do you all know of any floating rumors out there of the quicksilver bellows adhesive not holding up (or should I on) like years past?
Thanks...
