mercedes84black
Thread starter- Joined
- Aug 31, 2017
- 8
I bought a Johnson 175hp maybe early to mid 90's. It won't start, 90psi all cylinders. Sprayed starter fluid in the carbs after cleaning. It wouldn't start, just loud backfire from the prop. I turned the flywheel by hand and when the 1 and 2 piston was all the way up the flywheel tdc was significantly past the pointer (about 2-3 inches past) so could I have a sheared key
