2003 Johnson 150HP J150pxstm (carb with vro) What would cause excessive oil use? I noticed that when I had the engine idling for a short time I had a little more smoke than normal, oil/ water mix on the grass, and a good amount of thick oil on the inside of the prop at the exhaust. The oil Primer bulb is hard as a rock.
