ricksterpr
Thread starter- Joined
- Oct 31, 2006
- 6
Hi all, new to the forum.
Engine Mercury 240 v6
Upon turning on, excessive blue smoke came out of the exhaust. I mean a lot of smoke, enough to create a 10 feet high curtain. I idled away for about 15 minutes, and when accelerated, engine would no rev up higher than 5,000, all the while the smoke still trailing me. On middle and idle revs, no sings of failure. I decelerated and magically, the smoke disapperead and the engine started reaching full revs and speed on WOT. On my way back it happened just once again, but soon corrected itself.
A friend who has been around boats all his life bets 100% it is a clogged or water contaminated fuel filter. Strange since this filter has a sensor? I changed both filters and turned on at home, and smoke levels are at normal. Haven't had the chance of trying on the water.
Any suggestions as to the cause? I've read these symptoms are ussualy found on engines wearing out, and yes, my engine has around 250 hours. But my mainenance has been very very good, and 250 hours is not enough for a rebuild, in my opinion!
Side note - I have been using West Marines equivalent and just before this I filled with Quicksilver!
Your info is appreciated.
