Excessive oil from exhaust
Boatdontgo
What would cause a huge amount of oil to come out the exhaust? Compression is 105 and 103. The motor runs but not particularly smoothly.
F_R
Fuel that has gone through the engine unburned. Find out why it is not running smoothly and the goo problem will take care of itself. (SOME discharge is normal, but that is obscene).
F_R
Running too rich? maybe. Ruptured fuel pump diaphragm? maybe (if it has one). Running on one cylinder? More likely. Do some diagnosing before tearing into stuff.
Boatdontgo
It’s a 40e71b. I bought it in this condition. It seems to be using an excessive amount of fuel, most of which is running out the exhaust. I’ve pulled the carburetor off and cleaned it. The main jet and idle feed are clean. The needle valve and float test fine. It has spark on both leads. Both plugs look the same - dry and black. The oil return hose for the crankcase is missing. Don’t know if that would affect it too much though.
jimmbo
What kind of oil, and what ratio are you feeding that engine? When you put the carb back together, you did check the float height? Oil return hose?
Boatdontgo
50:1 oil mix. I did check the float height but can redo it. The oil return hose is missing. I’ll put a hose on and test again.
jimmbo
Oil return hose? Are you referring to the oil recirculation line, that goes from the lower crankshaft bearing to the upper crankshaft bearing?
Did you mix the fuel when the oils was added? If not, the oil will tend to settle at the bottom of the tank and for awhile the engine will get a very oil-rich mixture, then as the tank empties, almost no oil
F_R
I tried to hint at it, but make sure it is actually running on both cylinders, and reasonably equal power on each. Do that by removing and grounding one spark plug lead and see how it runs. Then do the same with the other one.
F_R
How far open do you have those carb needle valves? They are capable of dumping an enormous amount of fuel into the cylinders if open too far. 5/8 - 3/4 turn on high speed and 1-1/2 turns on slow speed for a beginning point.
F_R
Did you even bother to check for a ruptured fuel pump diaphragm or just reject the idea? EASY test is just unscrew it from the motor, leaving hoses connected, and give the primer bulb a squeeze. If gas squirts out the back side, the diaphragm is shot.
jimmbo
I admit, that has to be the worst case of 'some kind of guck' in a test tank, that I have seen.
I guess it could be a high fuel level, missing hi speed jet, a ruptured diaphragm, and no spark, combined
Edit: A 1971 40 hp would have an adjustable Hi Speed Needle, not a fixed jet
oldboat1
50:1 is 2 1/2 to 3 oz. 2-cycle oil per gallon of gas. Get a spark tester and measure spark gap on each lead. If spark is good (3/8 to 1/2 inch, and sharp), I would do the air mix as F_R suggests (initial settings shown). Look for a lean final setting (clockwise). Clean and regap plugs, and use the recommended plugs (Champion J4C gapped at .030).
With that much fouling, think I would pull off the l.u. and hose out the top of the leg and the bottom -- power wash would be good. Then have at it again. Sink it deep -- I would shoot for half way up the leg.
Think it takes a 20" oil return hose.
Boatdontgo
Thanks for the suggestions. It had spark on both HT leads but one spark plug wasn’t firing. There is so much oil in the leg that it keeps coming out but it looks like it is clearing. The high speed jet was too far out as well, probably because it was trying to run on one cylinder.
??----The high speed jet is not adjustable.----It is screwed in tight.
jimmbo
For some reason the 1971 40 hp had an adjustable Hi Speed Needle.
The model # of the motor must be posted.----May or may not have a fixed high speed jet / orifice plug.
