Re: Excessive fuel use
While I am NOT a guru on 2 stroke carbs, I do believe that they have some things in common with 4 stroke carbs.
There are little holes in them to allow air to bypass, which helps meter the fuel. If they are plugged you will get a rich condition.
A
good carb overhaul should clear up that issue.
If you don't know what your doing, have them done by a pro. Trust me, you will happier in the long run.
My old 84 johnny ran like **** until I had a pro do the carbs. Man what a difference!!!
