evinrude
Honorary Supreme Mariner
?????????----3 cylinder lower units do not fit on 2 cylinder 50 / 60 hp motors !!!-------If your motor is a 3 cylinder 1975 model than you have to check the shift motion is the same on the replacement unit.-----Later motors shifted to forward with an UP MOTION of the shift rod.----The early motors shifted to forward with a down motion of the rod !
The 3 cylinder 55 / 60 / 65 hp motors were from 1968 to 1972 and those were electric shift.------They will NOT work on a 3 cylinder 70 hp motor !!
