Evinrude
ken lee
I just bought an old Evinrude,serial #3034-11080, what is it? Also it seems to run good but I don't know if the impeller is working properly.
Is there a pee hole or some way to check?
Thanks in advance.
Bob_VT
Re: Evinrude
Sounds like a 1960 3 HP. Maybe Joe Reeves will give better insight.
Scaaty
Re: Evinrude
No pee hole on the little 3's., just mist from the little holes in the back with the exhaust, and it must be in a bucket of water to create a little resistence to push it out, otherwise it all goes out the bottom exhaust. Just put your hand over those holes...it should get wet. But its real simple to replace the impeller . I have 3 "Weedless" 3HP...best motors made
