Evinrude Won’t turn over no click
Ace2589
I have a 1987 Evinrude 40hp on my bass boat. Pulled out the batteries to charge after the trolling motor was slowing down. Since I just bought the boat recently I wasn’t sure which battery was for the trolling motor so I charged both. Reconnected both batteries and now I can’t get the engine to turn over. There is no click. Lights, fish finder, tilt, and trolling motor all work but I am getting nothing when turning the key. I assumed it was a missed connection but I have everything wired back the same exact way. Not sure what else I can try.
did you clean the battery cable connections and battery terminals?
take a multi meter and start tracing 12 volts....when you find the spot where the 12 volts disappears, then you found the area that needs attention.
