Evinrude what was wrong?
captdbaker
I'm looking at buying a 14' sea sprite. It's a 76 with an Evinrude motor. Guy said the motor was apart. The starter and propeller still needs put back on. I'm not expecting it to run but what I'm wondering is, what could have been the problem in the first place? I have attached a pic in case it helps.
jbcurt00
You'll need to get that info from the seller.
It could be anything and everything wrong w it.
Like I said, if it cant be made to run when you go to see/buy it, assume it cant be made to run and pay accordingly.
oldboat1
^^^Like he said. Opportunity for a parts motor. Maybe you like that particular hull, and would put a sister motor on it -- assuming that one won't run again.
captdbaker
Yes, that is one thing I have considered. Like you said, the hull is what drew me to it. A guy that used to fish with my cousin had one. I had an opportunity to go out on it once and fell in love. I did everything but offer twice what it was worth to try and buy it on the spot. Hopefully another motor won't be to hard to find if that ends up being the case.
emdsapmgr
I'd do a compression check on the powerhead before I put any $ into it. If the compression is good, crank it over and see if you can get it to fire once or twice.
