Evinrude V6 150hp 1996 stalls
Alpha4
Hello guys,
I'm landed here looking for a solution to the engine's issues.
In Italy there isn't a very good knowledge on this engines (and most of them dismissed) neither good literature.
The engine doesn't run smothly while cold and it's even worst when hot.
It seems that it's working only one of the two engine banks till it stalls.
to make it start again I need to go full trottle or close to it.
It's at least two years that I'm dealing with this problem without beeing able to use the boat
I've already changed the following parts:
- power pack
- spark plugs and wires
- flywheel cover (there was a crack)
- carbs rebuilded
- fuel pump membrane changed (still with VRO)
- forward/neutral/reverse switch
The engine has not been used a lot in its whole life.
Here an example of what's going on..
Any hint and help will be highly appreciated
Chris1956
Honorary Supreme Mariner
Well, that motor runs terrible. Are the spark plug wires on the correct spark plugs? Is the spark timing correct?
Do you have spark on all 6 cylinders? It sure sounds like she is missing and then running on multiple cylinders.
Are the ign coils good. Are they grounded properly?
Are any of the spark plugs real clean? That could mean water infiltration.
I would disconnect the SLOW system and see if that helps. SLOW will interrupt the spark to multiple cylinders, if it thinks the motor is overheating.
Is the motor in the water enough to pump cooling water?
Alpha4
thank you Chris.
I have spark on all cilynders, at least at low rpm and the ign coil are grounded correctly.
Motor is in the water enough. The position hasn't changed in the last 15 years
I'll take the boat in this days to another mechanic :yield:
