Evinrude V4 to V6 swap possible?
Tstroh
Hello! My first post and I'm looking for some help (surprise!). This is a long story so I'll try to shorten it...I bought a very nice Sea Nymph GLS220 about a month ago without putting it into the water. (100 percent knew the risk but the guy seemed legit, shame on me and a lesson learned) After resealing the lower unit and giving her a good tune up I hit the water. Idled out of the channel and proceeded to increase speed..all smiles until she started to plane out and started cavitating terribly (no more smile). Pulled it out and did some quick checks determined that the shaft length of the outboard was, much to my horror, TOO SHORT! (Tears now). The guy had changed the engine because the original had a broken crankshaft. Didnt even think to check that the shaft length was right before I bought it. I did get the original engine with the purchase so heres what I have...
1985 Evinrude 140 V4 Long Shaft VRO(runs good,too short)
1990 Evinrude 175 V6 Extra Long Shaft VRO( broken crank, correct length)
Big question, Is it possible to swap the powerheads?
I know the gear ratio will be different but I should be able to prop it accordingly to remedy the issue. I also know my other option is to get a bay manufacturing 5" extension kit for $700+. My thought is IF I can do the swap with what I have, I can put that money towards rigging the boat with needed fishing equipment. I am very mechanical but Im newer to outboards. Anyone got any knowledge that could help me make a decision? Thanks in advance! (Love this site, I've been an "outsider" for awhile...tons of great info! Glad I registered)
jbcurt00
A long shaft motor is too short?
The driveshaft is basically even w the bottom of the hull?
Got a pix of that?
Did the seller modify the transom to raise it?
Faztbullet
Sorry but no as the 140 is a looper and the 175 is a crossflow.....wont mate up.
Tstroh
Got a pix of that?
Its a offshore bracket mount. I should mention that I took it to the marina and had them verify my findings. We even went over it with a few of the techs to try to brainstorm a solution with bracket options to no prevail. My pic upload failed so I'll have to read on how to upload. Thanks
Tstroh
Faztbullet, I read last night that they made both V4 & V6 Loopers...how can I tell what I have? Or do you know via the model numbers? Thanks
The model numbers sorted that out for you.-Small atomic bomb required for this swap !
Tstroh
Ok. Appreciate you guys saving me from a lot of wasted time! I'll buy the extension kit. Thanks all for your time and knowledge
Tstroh
Got the extension kit from Bay Manufacturing...great to deal with, easy to install and fixed my problem! Took the boat out last Saturday and caught fish! Thats the end of this story. Thanks again for the help guys!
