Evinrude V4 140HP 1988 idle problems
timski
Hi People
For a while i having some problems with my engine running idle very bad.
By starting up it is very difficult to keep it running in neutral position.
When i move forward or backwards in slow speed the problems are gone but when you try to maneuver in slow speed the engine try to failout.
The total speed of the engine is good and is around 43mph and runs around 5000rpm.
What i try to do to fix this problem;
Compression Test (all the cilinders around 131 psi)
Carbs rebuild cleaning in ultrasone bad and replace the packings
Replace spark plug (Original Champion spark plugs QK77JC4)
Replace fuel filters and install gasoline Evinrude water filter
Replace head packing (a mechanic told that he inspect the cylinder in to the spark plug hol by camera and he saw a clean cylinder that are maybe because a water leak)
Everything above is done but the problem is still there an not fixed
https://www.youtube.com/watch?v=lffC3lq2TdY&feature=youtu.be
Can somebody help me here? maybe i need to do the syncing of the Carbs??
Regards,
Tim
Bosunsmate
Thats a big stutter your motor has, Have a look at your plugs see if any look different, see if that clean cylinder is still having a clean or rusty plug.
It could be an exhaust gasket leak into that cylinder
sutor623
You need to start with a link and sync if you removed the carbs. If two of those butterflies are open and the other two are closed you will have issues.
Have you done a spark test at idle? Sometimes the ignition system doesnt get a good enough spark at idle, and the only way to test is with a spark tester. DVA meter would help diagnose powerpack condition also.I got a remote control starter for $15 at autozone so I could stand behind my motor, pull the trigger on the starter, and check spark for all cylinders. It was well worth the money for doing compression tests on my own, spark tests, and especially doing Joe Reeves WOT timing procedure.
Do you have a timing light? Can you check the idle timing? I just found a big issue on my v4 looper with the quickstart. (Which yours has.) My motor was doing something very similar, and I jumped the black/white wire from the power pack to ground, and the hiccupping stopped. (That system increases the idle speed until the motor warms up. It does this by advancing the timing 10 degrees until the temp sensor says the motor is warm.) What I was experiencing was my timing going from 4 degrees, to 12-14 degrees at idle. This caused some serious hiccupping, and the motor stalling unless I was in gear going ABOVE 12-1500rpms. The timing was hopping back and forth and there was no way for me to tell until I put a timing light on it.
Are you sure both thermostats are opening at the right temp? A stuck open stat will keep one head running cooler than the other, creating issues. $20 at lowes will buy you a nice infrared thermometer. I had a thermostat gasket that had a hole in it, and my motor idled very poorly until I figured that out!!
What boat are you running to get 43 out of her? I have a very heavy Neptune (Hydrasports 20'er) and best I can get is 38 with smart tabs and 5500rpms.
timski
Thanks for all the information!! :D
To know that the engine runs beter afther the winter season by starting up, than doing all the fixed above;
sutor623, what boat i have; Glastron V-173 Bayflite
Some answers on possible fixes above;
Have a look at your plugs see if any look different, see if that clean cylinder is still having a clean or rusty plug.It could be an exhaust gasket leak into that cylinder
The head packing is allready replace for a new one included the sparkplugs. I found no any deviations on those plugs and head packing material it all.
I replaced also the thermostat assy packing on both sides to make sure there are no water leaks.
Spark test
Do you know theright values for the DVA meter? It is no problem to buy a spark tester but it takes some days to deliver and save some days to fix this.
Link and Sync process
This process i need to do first, is there found somwhere a good work instruction for that?
Timing light
Yes i have a timing light. So with this tool i can check if the idle timing is correct.
Thermostats
Howe i can check if the thermostats are still open? When the engine is turned off it need to close the thermostat?
And howe it make sense that the enige is cooler dan normal? When i sail more than a hour or less than 5 minutes idle are bad to and will cut off the engine.
Questions:
What are the right idle rpm to keep this engine still running? When is sail with this boat below 900rpm i need to give some power to keep the engine running.
Regards,
Tim
Honorary Supreme Mariner
????-----How could exhaust gaskets be leaking into the cylinder on this motor ??
sutor623
Tim,
Here is a link the manual for your motor, and to ALL of the electronic testing sequences. Before I dug too far into this, I would simply get a spark tester, remove all spark plug leads, and test spark plug wire when turning the engine over. There is a chance that you have a misfire at idle, that is clearing up at higher rpms. I like to work alone so I have a remote starter so that I can turn the motor over when I am right over my motor.
For link and sync and carb idle adjustments:
http://www.boatinfo.no/lib/evinrude/manuals/1973-1991johnsonevinrude.html#/0
Follow the steps in here to do a link and sync. After you do that, try to dial in the idle mixture screw on the carbs. If you are starving the carbs for fuel at idle, you will have idling issues. You want to screw the idle screws in to each carb until they are GENTLY seated, and then back the screws out the number of turns that it says in your manual.
Here is for electronics diagnosis. Simple and clean cut.......
http://www.cdielectronics.com/support/
Next I would simply check timing. Make sure quickstart is keeping the timing 10 degrees advanced, and when quickstart drops out (motor warms up) it should drop back to normal idle timing. This should be between eithe 3-5 of 6-8 ATDC, not sure which one for your particular motor.
Thermostats: By far the EASIEST and most effective way to test if they are opening and closing as they should is to buy an infrared point and shoot thermometer. I bought mine at Lowes for $20. Those thermostats should open when the water hits 143ish degrees. Check the temp of the heads and make sure they warm up to 140-150 degrees at about the same time, and then stay that way at idle. My motor will idle at 135-145 degrees for an hour while idling in a big 55gallon bucket. If you have an issue there, we will worry about yanking out the stats and swapping them.
I have said this many times, all of these tools are a great investment and a NECESSITY if you want to work on your own pre-ecu motors. For those who wish not to buy these tools, their work is best done at the mechanics shop:
Factory service manual!!!!
Compression guage
Spark tester
Multimeter
DVA meter
Remote starter (for working alone)
Vacuum guage
Infrared thermometer
BatDaddy1887
I had the very same problem with my 115 Johnson. It turns out the magnets in the flywheel came loose. Replacement flywheel solved my problem, I hope yours is as easy a fix.
sutor623
This seems rare, but it does happen. Boy what a frustrating troubleshooting process this can be, all for the simplest fix!!!
