Evinrude v4 115
Alex"thebign"2008
I have a 115 83 model when in neutral it revs fine and in reverse but in forward it will run about quarter throttle before it starts missing 13 mph is as fast as it will go Don't know if it matters but the choke solenoid is messed up
emdsapmgr
The choke solenoid is used only when starting the engine when cold. It can cause a problem if the red lever is not in the "run" position. Make sure it's not in the "service" orientation. I'd check to be sure the engine is firing on all 4 cyls. That engine will seem to run just fine on 2 or 3 cyls. Hard to tell just by listening to it. You need all 4 firing when it's under load in the lake. Do a Cyl-Drop test or check each plugwire with an inductive timing light.
