Evinrude trolling motor
TTracy
Was wondering how you know if it is a 12 or 24 volt. It has a 24c on the fin on bottom of motor???
Silvertip
Re: Evinrude trolling motor
A model number would help. Was this motor on a boat you just bought or did you just buy the motor without asking about the details.
TTracy
The model number is BF4PP 98. I got it as a gift was used.
NYBo
The best I can figure is that they made this motor in both voltages, based on this parts list. Try to match up part numbers for parts that are specific to one voltage.
TTracy
Forgot to tell you all it is a foot controlled steering.
STARCRAFT16SS
On my johnson trolling motor...the tag under the pedal on the foot control gave model # ...serial # and below that it said on the tag 12 volt....check
the tag again....it might be there....I also had a 12 on the fin...
STARCRAFT16SS
so much for the tag:(
Here is what my tag looks like...
you can see on the tag... 12 v.d.c. ...12 volts direct current
TTracy
Dont know trying to figure out. If it is 12 or 24 volt.
