Evinrude trolling motor problem??
T3hRustyWalnut
I bought a 98 bass boat with a bow mounted Evinrude trolling motor. I used the motor at one fishing spot and moved to another, set down the trolling motor and motor would barely turn or not turn at all. I checked for anything tangled in the prop shaft and the eletric is good to the plug. Could my motor just be shot?
Silvertip
Honorary Supreme Mariner
Re: Evinrude trolling motor problem??
Probably not but the battery might be. Just because you measured voltage at the plug does not mean the battery has enough capacity to run the motor. Try a known good battery or have the battery load tested at any auto store. You do realize the battery must be a deep cycle, not a car battery.
T3hRustyWalnut
Yes I have 2 new deep cycle batteries wired in series to give me 24v. I think it is just strange that it has been working for months and this happened
