Cougar_15
- Aug 11, 2008
- 93
Hi all, I am having some trouble with my TnT and I'm looking for some direction on how to troubleshoot/repair it. A little background, the TnT is off of a 1977 70hp Evinrude. It has the prestolite (3 wire) pump and uses one solenoid. I have the service manual for the outboard but since the TnT is an accessory it is not covered in the manual. The unit is off the motor.
There are a couple issues (that I know about), the first is that the left piston will not retract all the way to the bottom of the cylinder (neither under power from the motor nor by hand with the manual release open) and does not have any tension on it (you can pull it up with no resistance). When the motor is run the left piston does not extend or retract.
Below are 2 pics, the first show the piston as far down as it will go and the second shows it extended (by hand).
The second thing that does to look right to me is the seal on the top of the right piston, it appear to be leaking and when the piston it extended it is covered with oil.
So I'm looking for some ideas as to what's going on with this unit and some ideas as to a possible fix. The parts diagram has an o-ring kit listed for each piston but I have no idea how to take the piston apart...
