Walleye Man
- Mar 9, 2002
- 47
My 200 Rude has a hard time starting for the first time each day. I prime bulb is full of gas before I try to start it. After it has run once, it will be fine for the rest of the day. It seems like it is not getting choked by pushing in the key. I tested the voltage coming out of the switch when pressing in the key and get around 9 volts to the purple and white choke wire. I pulled the head cover off of the cylinders and when the key is off the cylinders are fully closed. Any suggestions?
