Re: Evinrude smoking, losing power @ higher RPM's
Bear,<br /><br />That is the very animal that I have! On the internet and everything, he he.<br /><br />I tested the compression in both cylinders. Pulling on the cord, I got 90 psi in both. I then cleaned the plugs and refilled the lower unit. I started it up and it did the same thing, however, I did discover something. When I disconnected the fuel hose to burn up the fuel before putting it away, I found that on the very last bit of fuel, right before it runs out, It runs like a striped ape. I repeated it a couple of times to make sure it wasn't just me, and it did it every time. I had it in gear with a good bit of throttle and right before it ran out, the rpm's came up and it sounded fine.<br /><br />This leads me to believe, through deductive reasoning, that it is a fuel problem, most likely in the carb. Does this sound right? Or am I way off base?<br /><br />Thanks alot folks for all of your help,<br /><br />cvlngineer
