Evinrude Slips Out Of Gear
AgTires4295
Forward gear only after full throttle, it slips into Neutral and winds at a high RPM
HighTrim
Re: Evinrude Slips Out Of Gear
Which motor are we talking about here?
You are positive it is slipping into neutral and the revving is not the prop hub spinning?
HighTrim
AgTires4295
Whoops I thought I put that in there. Its an Evinrude 25. Yeah no prop spin (thats what I thought at first too) bc I can see the shift lever fall out of Forward and into Neutral. It's just barely in neutral at this point because I can see it (the lever) vibrating where it's riding on the teeth of a gear.
lindy46
What year motor? If you hold the lever in forward at WOT, does it stay in gear?
AgTires4295
It's a '79. Yeah it stays in gear when I'm holding pressure on the lever in Forward. I even put a heavy spring on it to connect the lever to a forward piece to prevent it from falling back into Neutral position. Although just a temporary fix, it worked (but I have to connect/disconnect when shifting from F-N-R).
