Herb24
- Sep 15, 2013
- 12
Hi everyone and thanks in advance for your wonderful advice!
I picked up this Evinrude Ski Twin 33 with electric start a month ago. After cleaning the points and replacing spark plugs i managed to get it to run, so we took it to the lake and went for a spin. It seemed to run ok at low speed and idle was a little shakey but better after the engine warmed up. it seemed to run well WOT as weel abut after 3 to 5 minutes WOT it would start losing power and shortly it would be running at what seemed like a high idle in gear evin with WOT. we played with the high and low speed mixture settings and tried a few things but came to the conclusion that a carb rebuild was in order.
All of that tells me that this motor should run reasonably well with a tune up.
I proceeded to
-Replace all coils, points, condensors. and set gap to roughly 0.02" using a business card.
-replaced fuel pump with new one from my dealer.
-rebuilt carb with the evinrude carb repair kit. (new gaskets, float seat & valve, new boss gasket and put it all back together)
-new lower unit gear oil
now getting the engine back in the water it will run with the throttle lever in the start position, but i cant go to low speed or it will stall quickly, I can push it up to high speed although it doesnt seem like the RPM we had before the tune up.
Originally I had the carburetor float set to (high?) as it was flooding badly, so adjusted the float and now the fuel line bulb gets firm instead of spewing gas into the throat of the carb. However i still dont see much of an improvement if any.
if I put my hand over half of the throat of the carb the engine will stall quickly. needles are back out to manufactures specifications. My float is not set the way the manual shows tho, otherwise i just flood.
not sure what do to.
cant idle, not much rpm at wot, (in neutral) and adjusting needles rich or lean doesnt seem to help, anyting i do seems to stall the engine.
your help is apprecieated I'd love to get this running smooth and feels like i should be close, were going campin on the 27th for the weekend and want to take theboat.
I proceeded to
