FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
If it was an OEM OMC, yes, the 13 spline hub, but diameter can range from 12-3/4 to 14" on this engine.
13.25 diam would be a 17P, 13 diam is 19P and 13-3/4 is a 15P
The 14" diam can be 13-19P.
What boat do you have?
You have a problem if that is all the information you have. The only way reasonable from there is to find a prop supplier who will allow you to try multiple props until you find the correct match. I would take a WAG at a 13 x19 based on the power and boat description as a starting point. You will need to run Wide Open Throttle tests to find out if the engine reaches rated rpm with each prop you try.
