johnnybigrigger
- May 28, 2003
- 141
I bought an 84, 185hp Evinrude for my bassboat (18' Hydrasport). The motor came from a friend of mine as he purchased a new 150hp Johnson for his boat (18' Cajun) this spring. Our boats are the same size and close in weight, so I bought his 21p sst prop at the same time. When I took it out last week for the first time the engine only turned 4,800rpms, and reached 48mph. On his boat the rpms were around 5,800, and the speed was near 60mph. So, I rebuilt the carbs, and tried it out again. The performance result was the same, but I noticed a new problem. <br /><br />A cascade of water pouring from the lower cowling near the steering arm at WOT. I pulled the hood, and could not find any water inside the engine area. The water was coming out from an area that I could not see. I stopped by a local repair shop, and the fellow said the base gasket was leaking.<br /><br />When I ask if that would cause the loss of power, he said that was the problem. He went on the say that OMC had an updated gasket to prevent furture blowouts. Has anyone else heard of this causing a powerloss at WOT? I have owned several OMC outboards, but all were V4's. I never had a high rpm problem that was not cured by a carb rebuild.
