Evinrude peice of crap
walsalx5151
I took the lower end off of my 1951 Evinrude Sportwin mdl 4423 3.3hp and cleaned it right up. I put it back in, started it up to see if it worked.. but my engine still gets hot and stops... what do I do???
jim dozier
Re: Evinrude peice of crap
First you must never call an old outboard a piece of crap, you must talk nicely to it or you will offend it and it will never respect you. :D As a pennace you must re-remove the lower unit and install a new impeller (I guess a 1951 has a rubber impeller) and massage it with grease. Then perhaps it will forgive you and not get steamed.
walsalx5151
lol, ok.. The impeller is that rubber thing that looks like a 3 pointed kinda star???
flech01
Yes it is. Make sure to grease it up before install.
petrolhead
That's the one, while the lower unit's off you might try squirting some water up the pipe with a hose, to see if there's a blockage.
Dhadley
It might help to put the lower unit in water also.
walsalx5151
right underneath the screwdriver steering there are 3 little slits.. water comes out of them when i start the engine... but it still seems to run to hot. With the water coming out of those slits does that mean the water pump is workin? and what does the plumbing inside the motor look like? does anyone know where I can get a diagram that shows where the water goes in my 1951 Evinrude Sportwin 3.3hp mdl 4423.?
stairliftoheaven
hey ur piece of of machinery is older than me!!! bet its more efficient as well :D
walsalx5151
I do run the lower unit in the water, but after a minute or so it is so hot I could fry eggs on it. I put a water hose in it and blew to get the water circulating in it. It seems to work now. But after putting it all back together and trying to start it.... my recoil broke... Its just one problem after another with my old girl.
JB
Hang in there, Alex.<br /><br />When you get her right you will be her creator. :)
Hooty
"...my recoil broke".<br />It may forgive ya for callin' it a "piece of crap", but it won't forget. Kinda like a woman. :D <br /><br />c/6<br />Hooty
mologus
The problem is pointed out in all that you just wrote.<br /><br />Seems that you are not sure what an impeler(rubber thing) looks like. Than you say that you took it apart and 'cleaned it right up'. But then you ask if there is a diagram somewhere for this. This tells me you took it apart not quite knowing what you were doing or what to look for or fix.<br /><br />Now you say that it was running and it just stops after getting very, very hot.<br /><br />Now your recoil is broke and you can't start it.<br /><br />WELL, this simply tells me that you have probably seized up something in the motor or the lower unit. Or both!<br /><br />These old Evinrudes are GREAT motors that just keep on going. Calling it a piece of crap only tells me that you did not do the research needed before the work began.
