Ok, I have a 90hs Evinrude outboard. My Problem is every once in a while it bogs down and seems like the top cylinder is firing...i can only get max speed at about 15-18mph at full throttle. I've checked the wiring on the plugs, checked the plugs, cleaned the carb twice, checked the full and oil intake levels. And I'm running out of ideas of what's wrong. It use to run for about a tank and a half, then start bogging. When i leave it hanging up for about an hour or two it would work fine. Now...it only bogs. Any ideas? you can im me online with AIM:WereWolfy1 <br /><br />Thanks,<br />Brian
