Evinrude needs choking
Meaux
I recently acquired a 1974 4 hp Evinrude which has a remote tank. My problem is this: the motor starts and runs fine after about five or six starter rope pulls but in order to run I have to keep it about half choked. Adjusting the rich and lean valves does not help the problem. Do any of you fine people have any suggestions for me??<br />Thanks in advance-<br /><br />Meaux
D
DJ
Guest
Re: Evinrude needs choking
meaux,<br /><br />You have carburetor problems-no doubt. It's time for a carb. rebuild. It's relatively easy.<br /><br />If you have a cork float, replace it.
BillP
Ideas: fuel pump diaphram, clogged jet or dirty carb, air vent closed, bad hose connector. I've owned 4 of these (3hp & 4hp)motors...including a 74 model with the side throttle. Very easy carb to work on, pull the bowl and see what's inside.
Meaux
djohns19 and BillP<br /><br />Thanks for the quick reply---I'll check the fuel pump and carb repair---everything else checks out <br />OK---again--thanks<br /><br />Meaux
