Evinrude Lower Unit compatibility
77savy
I have what I think is a early 90's 120hp V4 looper. My lower unit has 2 1 inch groves on both sides of the lower unit above the tail fin above the prop. I'm wondering if a lower unit with the same size prop shaft with the 6 holes above the tail fin on both sides will bolt up? I have a guy that has a whole engine and lower unit for sale for $150. Its a 88, 85hp Evinrude. Just trying to see if this lower unit as well as the starter will work on my engine. Thanks ahead of time!
sutor623
Compliments of Fazt:
.....(This chart for direct bolt on with no part changes)............
Horsepower--------------------------------------Years that interchange
40/48/50/55/60..... (small diameter housing)..................1976-1988
40/48/50................................................ .................1989-1992
40/48/50................................................ .................1993-2005
70/75............................(20 inch shaft)......................1978-late 1981
60/65/70/75................................................ .............1982-1988
50/60/70................................................ ..................1989-2001
85-140.............(crossflow 13 spline prop shaft).............1978-1991
88-140.............(crossflow 13 spline prop shaft)..............1992-1998
120-140 Looper V-4... (15 spline prop shaft)...................1985-1991
75-115 60 degree........(bat wing unit 13 spline)...............1995-2006
150-235 & 2.6.................(crossflow V-6)......................1979-1991
185-225.........................(Looper V-6).........................1986-1991
185-225....................(Looper V-6 & Ficht)....................1991-2005
150-250.......................( Magnum Series).....................2002-2007
150-250........................(Lighting Series)......................1997-2001
jimmyebay
You have this model/fit breakdownfor the 175 horse?! 1987. Thanks!
