Evinrude Locked up
Gazman69
Evinrude 8hp. 199?. Less than 50 hrs. Sat for 15 yrs. locked up hard. Prop spins freely in neutral. Hate to brake it loose with a wrench to the flywheel. Suggestions?
oldcatamount
Take some Acetone and mix it 50/50 with automatic transmission fluid. Take the spark plugs out and prop up the motor so it's layng on it's face (with plugs upward) and put a couple tablespoons full of the oil you made in each cylinder. Let it sit for a day or two and gently work the flywheel clockwise (but, it doesn't really matter which direction you move it).
boobie
I've had motors so tight that I had to take the head off and use a wooden block and a hammer to rap the tops of the pistons. They eventually broke loose. Patience !! Have you checked the gear case oil ??
Chinewalker
If it were mine, I would tear it down to the crankshaft, plain and simple. Freeing it any other way runs the very strong risk of turning the motor into a large paperweight due to the possibility that there is rust along the crankshaft line. Even if it's just the pistons stuck, the rings could be stuck in the grooves. Tear it down, clean it up, replace any bearings that are rusted, free the pistons & rings, and put it back together. If it's something simple sticking it, you'll feel better knowing it wasn't something worse.
