GlassmasterSC
- Dec 31, 2005
- 22
My 1982 Evinrude 115 is dripping oil down the leg of the motor all the way down to the bottom. It appears to be coming from the base of the powerhead, but if you take off the cover, you can see oil all around the base of the inside of there too. The motor seems to run fun otherwise and the water pump is working. Also have steam coming out of the exhaust ports/buring oil smell. I want to replace the gaskets and water pump before the spring season. There is a complete gasket set for my motor for sale on Ebay right now with a starting bid of $50. Is that a good deal? Any other recommendations for the motor? Any help would be greatly appreciated, I still have a lot of learnig to do. Thanks
