SquirrelTurds
- Mar 31, 2014
- 14
I am trying to determine if my engine is misfiring at high rpm's because of a bad fuel mix, or timing. Here is a video: https://www.youtube.com/watch?v=80L3-aDPgwk&feature=youtu.be Compression on the top cylinder is 118 bottom 114. Water pump works perfectly FYI. I accidentally used lucas 2 stroke oil which is not environmentally kosher for boating, but I don't see how that could change anything! However here is what it looked like after a 10 minute run (I will switch out to the proper oil before I put it in the water)
