I bought a 70's bubble manifold 135hp evinrude. With a bad stator (ran pretty good but low voltage from stator caused weak spark and wouldn't keep the battery charged) After a few months of trying to get the flywheel off and breaking multiple pullers I finally got it off. The bad news is I had a puller break and smash the beginning of the threads. So there is a giant dent in the top of the threads making it impossible to accurately re thread. I have tried a thread file and have just had no luck.I thought about trying to cut and weld a nut around it and back it off but I don't know if that would even be possible.. After the first few threads its fine. I just dont know what to do. Is the right thing to do to go down to the next thread size or just buy a new crank and do a full rebuild. The current flywheel thread size is m22x1.75. I didnt know if a m20x1.5 would work if i could remove the current threads and re tap it. I'm just clueless, I also have another question. The motor came with a working tilt trim pump with frayed wiring. I bought a new pump and I just cannot get the motor gear to line up with the pump when I try to put it back together. Any help on either one of these problems would be great.
Thanks,
Ben
Thanks,
Ben
