Evinrude Fitch 2002 oil leak/leaks
thatone123
Banned
This outboard is leaking oil out of the upper and lower cowling. It has a jet on the outboard, not prop. It is not serious just a small trickle. If I remover the lower cowling will I be able to access the problem and what could the problem be?
thatone123
Banned
I tried to take off the lower cowling but after taking out the bolts it won't come off. I'm thinking the oil leak is somewhat normal from the caked residue , seems it has run quite a while that way.
daselbee
Fighting the same problem right now on mine.
It is infuriating. On mine, there are no leaks from pumps, lines, fittings, etc. But the lower pan gets full of oil.
The only thing I can see is a drop of oil on the bottom of the throttle butterfly shafts that extend thru the bottom of each cyl's throttle plate.
Fazt knows of the problem, has commented that there is a "kit" to fix it, but my Evinrude dealer knows NADA of such a kit.
Please update if you arrive at a fix, and I will do the same.
thatone123
Banned
OK...will do, I thought someone would know something, but I guess not. Did you get the lower cowling off. I took off the 4 bolts but it is still stuck on there. Can't split it in half? Madly searching the Internet like Abby would to LOL, but no luck!
