evinrude fisherman engine id
mondoreli
good day all..<br /><br /> an older fella down the street has an older o/b for sale. can anyone id it?<br /> 54028 E05955 appears to be the #s on the tag.<br /> any help would be invaluble, also would this be a good buy for $50. it runs<br /> thanks<br /> mondo
Paul Moir
Re: evinrude fisherman engine id
That sounds like a '64 5.5hp outboard to me. That's model number 5402. Is it like this one? <br /><br />Outboards from that era are cheap and easy to fix. $50 for a runner of any type would be a steal though. You might want to check the compression before buying. It ought to be greater than 90 psi, and within 10% of each cylinder (ie, 90 and 100 psi would be unacceptable compression.<br /><br />If it is a 5.5, (and not a 6hp), run it at a 24:1 gas/oil mixture. The 6hp fisherman is rated for 50:1. (and is totally different internally.)<br /><br />Good luck!
