Leo Fabiani
Thread starter- Joined
- Jul 5, 2014
- 2
Hello
i have a outboard Evinrude Ficht 150 two stroke engine 1997 model
P/N E150ILEUC
while crusing at normal speed engine just shut down and never restarted i checked everything like per service manual and everything seems ok
sparks are firing on cilynders but there is not fuel injecton into the cilinders (candles are clean and without trace of any fuel)
cranking is 198 rpm , batteries full (as per diagnostic), sparks ingited and voltages normal, fule pump in normal pressure range
no alarms or fault, cps is correct and working
i did static injector test and every injector click normally
i checked everything the only things i notice is when entering diagnostic trhoug serial cable :
1) display and error that injector of cylinder 1 has no serial number, please correct (can't correct because in the diagnostic there is no page where to enter serial numbers, what shoudl i do?), error remain
2) i started 5 hours oil injection just to try and the motor seemd to ingite the exceeding oil but still no way to start it
is it possible that no serial on ijector prevents engine to start? should i buy new injector?
how to restore serial number???? in the diagnostic there is no tab/menu to do that (in help it's showed)
it seems that for some reason the ecu doesn't send signal to fuel injectors to throw fuel into the cilynder
i suppose it should be ECU fail since there is no other component not working
as per your experience is that possible?
thanks in advance
P/N E150ILEUC
thanks in advance
