Evinrude Fastwin 18 1957 (old topic, but new question)
caninesinaction
I have completely rebuilt 1957 Fastwin 18, all new electricals. I have read the post describing setting the point gap. For reference, good spark on each plug, correct wiring, carbureator completely rebuilt. Set points at 0.020, at point rub when aligned with cam key. Motor will not start, just pops like a back fire or if plug wires were wrong. Motor has run before. When I set the points according to cam reference to points rub, both pistons are almost at bottom of cycle (spark plugs out of holes).
I was taught for many years that points open just before top dead center of piston travel when gas is compressed fully. What am I missing.
F_R
Honorary Supreme Mariner
One thing you got right---points open and spark happens when it is time to fire (near TDC)
oldboat1
Initial carb mix (idle) is about 1 turn open, half to 3/4 open for h.s. needle.
Post some pictures of your magneto.----Which coil / point set are you looking at when # 1 is ar TDC ??
caninesinaction
Looking from the back of the motor (spark plug end), the top piston is at top dead center, both sets of points are closed.
caninesinaction
Cam is not upside down, cam has "etched" TOP inscribed on it. I have tried the needle valve settings on carbureator as described, plus various settings on the HS needle valve.
Chinewalker
The front coil fires the top cylinder. Make sure the coil primaries are wired correctly. Looking down at the coil nearest to you, the primary should be routed to the points to your right.
caninesinaction
some additional info. I reset the points to .020, at the exact reference point of the cam key and the points rub. checked to see if that was consistent with observation hole in flywheel for setting the points without taking the flywheel off. Right on the money, so I know that is the right reference, but still puzzled about piston location over 1.5 inches before top dead center. Same for both cylinders. Points open well before piston completes its travel to top.
caninesinaction
Chinewalker: I do have the front coil wired to the top cylinder, and both are wired correctly. The front coil is wired to the points on the right. Thank you.
I still can't understand the position of the piston top relative to the points opening being so far from the top of the piston cycle.
Put throttle handle at slowest idle and see where pistons are.-Also google ------universal magneto------For lots of tutorials on this simple magneto.----I have worked on them for near 50 years with nothing confusing like what you are seeing in this case.
oldboat1
Did you run this motor in the past, or is it new to you (maybe advised it was running)? Has compression been checked?
I think I would pull off the flywheel again and check assembly. Make sure the flywheel has not moved (torque issue). Check the mag. plate to make sure it's tight -- should be no wobble. Check to see if a coil is loose. Also, check to be sure all wires are tucked in and not making flywheel contact. I don't think there was a cutoff button until '58, but somebody might have installed one -- possible factor, although usually a no-spark condition. (Look for extra wires -- two black wires, typically with clips or knife connectors at the ends.) And just for grins, make sure the flywheel magnets are strong (can check by dangling a small screwdriver).
On carb settings -- should be sensitive to small mix adjustments, and the "link and sync" must be done. The roller should touch the scribed mark just as the throttle plate begins to open. Check the idle stop screw to make sure it isn't set unreasonably high (maybe to compensate for other running issues).
F_R
The spark advance is controlled by the throttle, which rotates the mag plate. So at wide open throttle the points break earlier than at idle. Actually at slow idle they probably break After TDC. I really don't know the number of degrees at WOT.
