Evinrude engine vibration
bmordo0193
HI guys, I have an evinrude ocean-pro 150hp v6 1995. The engine runs smooth at any rpm under 1000 and above 1500rpms, there is a vibration at the rpm range in btween. I changed the plugs to see if I had one that might be on the way out, but the condition hasnt changed.This engine has oil injection. The prop is a stainless 3 blade and is in perfect condition. Any sugestions as to where to go next.
walleyehed
Re: Evinrude engine vibration
Take a better look at your prop.....you are discribing exactly what a slightly bent blade will do!!!!!!!!!!!<br /> :)
walleyehed
Matter-o-fact, if you have a spare prop, try it. That will atleast eliminate that if that's not the problem....sometimes a blade can be bent so slightly you don't see it, but man, it will vibrate, trust me.... :D
seahorse5
Chances are you are experiencing the results of not having the carb opening and spark advanced synchronized. This linkage adjustement is commonly called "sync and link" by mechanics. The factory service manual has an illustrated step by step procedure to follow.<br /><br />It is critical as in that rpm range, the carbs are changing over from the low speed circuit to the mid or high speed circuit and run a tad rich.<br /><br />Other factors come into play also, such as inoperative thermostats, improper idle screw adjustments, too "big" a prop, etc. Make sure you are using the recommended Champion QL78YC plugs gapped at .030"<br /><br />If you don't have a book, hire a QUALIFIED tech as it only takes a short time to go thru all the adjustments on the linkages.
walleyehed
Seahorse just got me again because I can't read........I see now it runs ok above 1500, and ok below a 1000. I Apologize for the misleading info........... :rolleyes:
angus63
I have 95 175 oceanpro and went thru this also. Readjusted carbs,sync and linc, prop balance, etc.. After running this by several people with the same motor (mid 90's 150-175) everyone had a similar condition. Sat down with local omc guru and he tells me not to worry. It is set-up for a wot timing of 20° btdc and idle of 0-4° atdc. Initial cracking of the throttle provides an increase in timing not proportional to the additional fuel supplied.The transition from idle to intermediate jets play a role too. In summary, avoid 1000-1500 rpm as much as possible but don't worry about the shimmy.<br />PS- You can play with jet changes, but the guru says it don't help much and can lead to other issues.<br />GOOD LUCK
