Evinrude e15elctr remote start
Bigrift
I have a evinrude e15elctr that has electric start allready with one button to start motor another to stop the motor. I would like to extend the buttons to my console without removing the ones on the motor. If i can avoid splicing into the exsisting wires and attach wires to the same points as the others that would be ideal. Problem is i cant figure out whats going where as most of the wires go under stuff i cant see. Anyone have a idea on what to do? A diagram of the wireing maybe? Thanks.
Solved. I took the air intake off the carb and was able to better trace,the wires. One went to power pack another to the nutral saftey and one from battery. Hook them togeather and bingo.
flyingscott
If the original starter push button is on the motor I believe they are sealed. You would need a new push button that can handle 40 amps. Then you would need to run the positive battery cable to the push button and one from the push button to the neutral safety switch. Then you would need to run the alternator red wire to the battery + terminal. You would have to extend the kill button wires to the front of the boat for that button. The - battery cable can stay where it is. If you do all this you will still have to walk to the back of the boat for the choke. There is a kit to convert your motor to do what you want but it is expensive. That would involve an electric choke solenoid and a starter solenoid also a key switch. Seems like a lot of work, I have the same motor I just run it the way it is on remote controls and walk to the back of the boat to start it..
