Evinrude E120TLCEM coil pack?
bcsukas
I have a 1989 Stratos FS with Evinrude E120TLCEM, can anyone tell me where's the best place to find coil packs? As I've stated on previous posts I'm losing power after boat runs for 10 or so min. I've changed all the fuel lines, and going to test tomorrow, but after talking to a couple people around town, the first thing they mentioned was the coil packs. I've changed the coil packs on my F150 and after thinking about it, the two correlate pretty good as to the symptoms.
Thanks for your help.
Haffiman
Re: Evinrude E120TLCEM coil pack?
If ignition related, abrubt misses or shut down. If fuel related, more of a surge.
Check compression, check spark plug colors, check engine timing with a timing light. Test on all cyls that you do not loose any. A good diagnosis might save you a lot of dollars.
