Evinrude does not start-help!
louie2
I have a 77 Evinrude 25hp motor that does not start. It has spark, gas, and on occasion will fire, but does not run. I am missing the manual. Is it the points? How do I change the points? Any other ideas? Any help would be much appreciated!
12Footer
Re: Evinrude does not start-help!
If it has spark, it aint the points. Spray some WD40 down the carb body and see ifn it fires. If it does, it's a fuel delivery <br />problem. If not, check the timing. Prime suspect is the flywheel key has sheared,throwing the timing way out.<br />Good luck and tight llinez.
