Evinrude Charging Problem
Steve22
1989 60HP Evinrude w/ charging problem.
I removed the rectifier and the back side was all melted, so I know I at least need a new rectifier.
The lower screw of the rectifier has a funky design, it threads thru an assembly then two wires attach (with eyelets) and a nut on the back side completely out of sight! I never would have realized this until the nut slide down from behind the asssembly. I have to remove the assembly to be able to see and reattach the wires and the nut, I digress. I hope I'm putting it together properly.
My question is, How can identify Stator Coil and test?
Is there anything else I should be checking as well??
Thanks!!
Joe Reeves
Re: Evinrude Charging Problem
Best not to have duplicate posts Steve. I just entered another reply in your original post.
