Evinrude Big Twin 40 solenoid question
chadillac7
Working on getting my old Lund on the water. I completely rebuilt the wiring harness today for the Big Twin and the motor now turns over...but not every time. I get a click form the solenoid every time, but I don't always get starter rotation. When it cranks, it's all good...but I'm scratching my head on the solenoid. I do aircraft electrical systems for a living, and usually with the starter solenoid, if it is clicking closed, power is flowing through to the other side...unless it is corrosion fouled (still closes, makes the click, but no current making it through). That may be the case here, but thought I'd post it up here before ordering a new solenoid.
Anything else I should look at before ordering new?
boobie
Easy to check out the solenoid with a battery, some jumper wires and an ohmmeter.
oldboat1
Believe I would get some sandpaper and clean all connections first, starting with the main connections at the battery.
F_R
Honorary Supreme Mariner
I fully respect your position as an aircraft guy. But it almost scares me too. You have an understanding of how the solenoid works. Surely you know that the way to check it is to check the voltage on the big cable sides while it is "clicked" and failing to crank. Battery voltage in and low or no voltage out indicates a bad solenoid.
chadillac7
Absolutely do understand how they work (and yes I've checked the setup with an ohmmeter). A little more background...built three airplanes, flew jets and turboprops for 7 years, sold airplanes for 12 years, my other boat is a 27' express cruiser...but I have very little experience with an old 2-stroke motor, so I just wasn't sure if there was anything else to look at that is 2-stroke specific. It has cranked every time today, so my guess is the solenoid was just idle for too long and needed to be worked. I still may replace it just for peace of mind.
Thanks guys. Great forum and info.
F_R
The solenoid may be bad, no argument there. But there may be people here reading this that do not know enough about electricity to change a light bulb. For their benefit, lets clear something up. An ohmmeter is not the preferred tool for testing a solenoid. A piece of 20 gauge wire will show zero resistance on the ohmmeter, but certainly will not pass the high starter current. A voltmeter to check voltage drop across the solenoid contacts will disclose the resistance to high current. Key words are "voltage drop".
Agreed?
chadillac7
Agreed. Same tool though...correct, we are measuring VOLTAGE, not ohms. I'll correct my post...well, if I could edit it, I would.
