evinrude backfiring
gomer68
I picked up a boat back in the winter,and after going over some of the small problems. i started it today, and after warming it up...i brought it back to idle and it back fired every couple seconds.but when i rev it back up and it doesn't back fires until back at idle..any ideals?? thanks. sorry 1998 130 hp etec
Bosunsmate
Re: evinrude backfiring
Carb blockage, put your hand in each carb throat to act as a choke until you find which one it is, or clean them all
Are you sure it is a 1998 E-tec ----Best to post a picture or a model # because your information is not right !
It is a 1998 carbureted looper engine.-----Try opening low speed mixture screws 1/4 turn each.
gomer68
racerone your are right, its a 1998.I will give it a go maybe one night after work thanks.
