Evinrude alarm
James@jnjcustomhms.com
I have a 98 evinrude ocean pro 150 and alarm goes off at 4000 rpm but if a kill it within seconds I can restart it no alarm until today and the alarm went off at 3000 and once at an idle same thing though kill it and it will start and no alarm I brought it home and hooked it up to water and ran it for over an hour i that hour I ran ir for ten min at 5000 and in the hour no alarm but every time I am on the water and I hit 4000 it goes off by the way it is a solid squeal non interrupted . I have had it in the shop at least 6 times replaced the thermostats but they can't find any thing wrong they say it must be overheating but I had grass sucked up in the intake once before and it overheated and alarm went off and I killed it but then the alarm cuntinued whenever I turned on the key until it cooled down . Unlike what it is doing now am tired of hauling it to the shop spending money and time with no fix does anybody know what the problem may be
OK, did they rebuild the water pump, along with new thermostats?
Have you check tested the overheat sensors?
The motor should limit speed automatically if it detects overheat. Does it do that?
Do not run the motor at high RPM with no load on it. The test proves nothing without a load, and the motor may just break.
That motor have the oil injection installed? Is the oil tank full? Is the OMS pump working properly?
